Change gear without pedalling - HxR EasyShift
Rossm
Anyone else seen this? Or ridden it??
http://hxr-components.com/en/products/464-pedalier-hxr-components-easy-shift-kit-3.html
Interesting concept - move the free hub from rear wheel to the crank & fix the rear hub. So the chain is always running & you can then shift without putting in pedal strokes. It only works for 1x systems, and as the rear is essentially a fixie, there might be sudden pain if a chain drops :heh:
Benefits in quick shift on lumpy terrain & fast corners??
No a new concept, it was tried years ago. The chain moving the whole time seems to be a bad idea. Smashing down a descent, not pedaling to keep tension on the chain seems like a recipe for chain drop. Also having a moving chain next to your legs while coasting doesn't seem the best idea. Might be ok for commute with a full chain guard though.
Yeah, they mandate a chain guide with the system. Dropping a chain has the potential to destroy the entire drive train, rear wheel, chain and seat stays.
