singlespeedfreeride
Cycleworld
We are currently clearing out some of our mountain bike parts and accessories, including high quality components such as Sram X0 and Shimano XT. If you see a better price for these models anywhere, please message me about our pricematch policy. All these parts are new, some cranksets are OEM models however the shifters and derailleurs are in their packaging.
Sram X0 Rear Derailleur: $269 now $89
The X0 rear derailleur features a carbon and alloy construction, using a sealed cartridge bearing and 6061 aluminium, it is light enough for cross country, weighing in at a mere 200g, but tough enough for downhill. Whatever your riding style or trail conditions, the X0 is built to handle anything you throw at it. note that these are the previous generation 9spd Sram X0
We currently have 2 medium cages, one alloy and one carbon, and 2 carbon long cages.
Sram X0 Shifters: $279 now $179
The X0 shifters feature a carbon fibre construction, with aluminium hardware and clamps, making it super lightweight at only 225g (claimed by manufacturer). Coupled with unparalleled performance for any riding style and in any riding conditions, no wonder it is the top choice of Mountain bikers worldwide, from downhillers to xc racers.
We have 2 pairs of shifters, both are 9x3 spd and are a previous model.
Sram X9 Front Derailleur: $89 now $29
The Sram X.9 High clamp, Top Pull front derailleur suitable for Triple chainring setups. It uses a dedicated design for top-pull routing applications, and uses a High clamp design. They are a 2007 model.
Shimano BR M965 Caliper and rotor: $289 now $69
The BR M965 Brake caliper features a super lightweight Mono-body design and provides superior control performance, the caliper also comes with a 2-peice 160mm SM RT96 centrelock rotor, providing plenty of stopping power.
Shimano XT M770 Crankset: $299 now $219
The Shimano M770 Triple chainring crankset utilises Hollowtech II crank arms to offer unrivalled strength to weight ratio, SG-X chainrings offer a precise gear shift and are compatible with HyperGlide Chains and cassettes. Rigidity and hardness are increased with an advanced design due to more separated bearings and wide axis. The cranks come with 9 speed chainrings with ratio 44/32/24 and are supplied with bottom bracket bearings suitable for shell sizes 68 and 73mm
Thompson X4 Stem 31.8 clamp 100mm: $189 now $89
The Thomson X4 stem allows you to realize the benefits of stiffer forks and stiffer 31.8 bars. X4 offers precise steering, tracking, and more control while riding, all wrapped up in a beautiful design.
The Thomson X4 is stronger and 30 grams lighter than the Thomson Elite 25.4 mountain stem. It features a traditional steerer clamp that is shaped to save weight and to be knee friendly. X4 is absolutely the best combination of strength and weight available.
Shimano M542 Deore Cranks: $155 now $99
The Deore Crankset features a durable alloy construction featuring Shimanos Hollowtech technology. A Triple chainring setup provides you with a wide range of ratios. The crank arms are 175mm long.
Shimano M552 Dyna-Sys Cranks: $169 now $89
Great value 2-piece design chainset for 10-speed Dyna-Sys transmissions. 10-speed HG-X chains, the 2-piece design chainset features an external bottom bracket system which is a lightweight rigid design that is incredibly strong and durable, and aluminium outer with steel/composite middle and steel inner chainrings keep it lightweight. The crankset comes in 175mm only.
