mike-
Clips 'vs' Flats
I'm doing a bit of a thread about each, describe them,pro's and con's of each but yeah, I'm not saying what is BETTER, but more giving you reasons to make your own decision.
Flats:
A pedal, generally made of metal, sometimes made of plastic, and your foot just sits on it, pretty simple
Pro's
Con's
Clipless Pedals (Clips)
Clipless Pedals, normally called 'Clips' are pedals that you slide your foot into a locking mechinism that hols your foot in place on the pedal, and the foot must be pushed sideways to remove it from the pedal.
Pro's
Con's
After doing this, I see a pretty big list of pro's for flats, and con's for clips, but myself I ride clips when racing, just for the fact that you can get the extra power and acceleration. But pedal choice really is a person preference. Ask your buddies for a turn with their clips and see how you like it, don't let people decide for you.
Hopefully this helped some people thinking about what pedal to use.
Rage away
Flats:
Pro's
- Easy to get feet on (eg. coming out of a corner where you put your foot down).
- Easy to take your feet off (eg. In a corner or bailing).
- Simple, require little maintaince or work.
- Generally slightly cheaper.
- Can use any shoe.
Con's
- Can only push down on pedals, can't pull up aswell.
- Can make a bike harder to pull around ('CAN').
- Shindigs. Ouch, slipping the pedal.
Pro's
- Push 'n' Pull (Push down with one foot, while the other pulls up) Gives you more power, and acceleration.
- Attached you to the bike, in the air this can give you the little bit nessecary to get you over that jump sometimes.
- No shindigs, peadls stay stuck, through the rocks, corners, and at high speed, everywhere.
Con's
- Requires propper shoes.
- More expensive.
- Can wear alot faster and needs looking after.
- Your stuck to your bike, so no bailing or putting feet down in corners unless you unclip, then clip back in.
Rage away
