yeah i tried that but its on the free body side so its recessed and you cant get the the back edge of it.Cant get to it from the other side with a long flat head screwdriver and a hammer?
might try the cutting disk option.Heat gun? Small die grinder with a cutting disk attached (its a bitch but I have done it.)
Failing that find a mate with a tig welder and add material to the inner of the ace and try and tap it out using a screw driver. Just dont weld the race onto the hub
That's generally the first option, but when the bearing has shat itself & only the outer shell is left there's not much to hit against.Cant get to it from the other side with a long flat head screwdriver and a hammer?
