I would take pictures of what you have. Older Commencals used some funky BB setups that don't usually end up working well with external bearing type cranksets.I purchased a raceface evolve dh crankset. X type 68/73mm bottom bracket which I assumed would fit. The crank arm spindle overhangs about 3 cm from the bottom bracket cup, which means if the non drive side crank is in its proper position, the chainring is 3cm out from the taco and chainguide.
Therefore I assume I need a shorter spindle, or is there another way to fix this that I haven't thought of.
Rear hub size is 135mm spacing. Ive got two washers between the backplate and the ISCG, is that right?I would take pictures of what you have. Older Commencals used some funky BB setups that don't usually end up working well with external bearing type cranksets.
For example... 68/73mm BB shell and 150mm rear hub spacing gives you a very mismatched chainline, and causes issues with the frame/guide setup. What is your rear hub size?
The RIDE DH cranks are the next closest thing to the Evolve DH cranks...make sure your BB spacer setup and RF spindle setup is correct. From there, your guide should be spaced out with the included washers between the backplate and ISCG mounting surface (tabs on frame or adapter plate).
Cheers,
philip @ theHive/e*thirteen
Yeah, I thought so. If I were to buy a 68/73mm crankset, that should do the job? Is that right?Looks to me like you've purchased and 83mm DH crankset and it's too wide for your 68/73 bb....no solution for that except a different frame or a different crankset.
This is correct. You've got the Mini Supreme. An 83mm crankset shouldn't be too hard to find a new home for. Any 68/73mm crankset should work out as far as spacing goes.Looks to me like you've purchased and 83mm DH crankset and it's too wide for your 68/73 bb....no solution for that except a different frame or a different crankset.
