kind of depends on what you don't like about your 36t set up
and if you have granny ring studs or not?
is the lowest gear too high?
is the highest gear not high enough?
for a 104mm BCD crank the general rule of thumb is to not exceed more than 10 or 12 teeth between chainrings
so 22/32 etc works best
granny rings range from 22t to 28t (there may be some obscure 21t or 29t option)
middle rings run generally from 32t to 38t but can potentially go as big as you can buy?
if you have granny ring studs then 24/36 will give you a really broad range of gears
if you don't have granny ring studs and are running a middle and outer set up then 32/42 may be your man
dedicated 2x10 cranks run a different BCD, smallest small ring you can get is 26t.
they also tend to be wider ranges too, 26/39, 28/42, when you match them with 10 speed cassettes you get almost the full rang of a triple ring with a 9 speed set up
