hifiandmtb
Sphincter beanie
Could be tricky now @DMan had it welded up. Still worth a try.has Trek issued a recall, easily checked...might get a new frame out of it
You will never know.Are you being sarcastic?
Of poor heat treat failing to normalise the tubes post weld.If it's like that MTBR pic then that crack is the typical crack at the edge of the weld heat affected zone. Nothing to do with a bit of extra shock travel. May be a design flaw.
I looked at the Trek website and there's nothing about Full Stache 8s. The tape is holding the weld together thoughI think the problem is your tape @DMan . It is on too tight.
So have they issued a recall or not?
Split pivot (concentric to axle)Is there a pivot at the rear axle? Hard to tell in the photos.
Thought so, 130mm seemed too much travel to not have movement there.Split pivot (concentric to axle)
a mate had a fuel go in almost the same spot, though he has a pair of cracks, 2nd one is very close to tyre, keith rubbed a crack in the frameI looked at the Trek website and there's nothing about Full Stache 8s. The tape is holding the weld together though
I'll just have to keep breaking it for a while then. But long story short, it sounds like dropping the travel to 130mm won't affect much...
I would imagine the bike can withstand much heavier people than yourself, so even if the 10mm did place some extra load on it, it should take it. Just make sure you're not bottoming out your rear shock and not jarring or load shocking the frame on big hitsI'll just have to keep breaking it for a while then. But long story short, it sounds like dropping the travel to 130mm won't affect much...
That's the million dollar question. I don't think it had had a hard life though. He'd only had the bike for 6 months and had spent more time upgrading it trying to get it to ride like he wanted. I've never had a band on the rear shock so I actually don't know how much travel I use. I do know based off "dust" rings on the stanchion that I've never bottomed it out. I'm going to work out how much travel I'm using on the rear because I might actually be running it too hard and not using enough travel.I would imagine the bike can withstand much heavier people than yourself, so even if the 10mm did place some extra load on it, it should take it. Just make sure you're not bottoming out your rear shock and not jarring or load shocking the frame on big hits
I wonder what type of life the frame had before you bought it ?
I'll post a pic tomorrow. I should have taken one before i taped it up!!Funny spot for a crack - it is too far from the weld for it to be a factor to me.
Is there a hole drilled or something under the stay to attach the chain silencer?
Got a pic of the repair?
Even so, if its a known problem....Second owner.
new bike time.
