If by crank hop, you mean pedal kick. and by clutch hop you mean using the motor to launch forwards and controlling it with a clutch, then i would guess they are similar.
they are similar in regards to body position and you obviously use the clutch or pedals to hold your front wheel up so the concept is the same, but clutch hops on a motorbike are definitely a LOT harder!
