Labcanary
One potato, two potato, click
You know what you need to doOrange offered me a new Pro 5 for a bit less than that. Felt exxy when they first offered, am rethinking that now I've seen what their retail is!
He won't though.You know what you need to do
We've been telling home to torch the Renault and Alfa for years.He won't though.
Someone else out there has your approach to fixing old MeganesWe've been telling home to torch the Renault and Alfa for years.
Lol, four hits with a sledge and didn't even break anything! So quaint.Someone else out there has your approach to fixing old Meganes
If the sound in the engine not goes away then do this? #mechanic #shortsfeed
#engine #noise #problem If the sound in the engine not goes away then do this? #mechanic #shortsfeedYour Queries:-engine missing problem, engine noise, ...youtube.com
Yeah, I just ran out of patience with it… It was like this (not as bad though) before I pulled it apart, so I think it was manufactured with too much preload. I did check for burrs or debris in the seat of the bore.How are the bearings spaced? Floating tube between bearings with a straight able or axle with machined lips to spacer the bearings?
Pressing a bearing in (particularly if cocked) can create a burr up against the outer race face which will result in the bearings being preloaded too much/being crunchy when you tighten the axle. Pull the main hub bearings back out and give it a good clean.paying particular attention to the faces on the hub body where the outer bearing race is pressed up against.
Those green Hope hubs I bought don't.Silver goes with anything.
I’m suspecting that’s what helped them offer a nice price… Hope they still send it!You might get a very special price from Orange now they're in Administration..
