stinky1138
First foray into the world of DS. Bought off the forums and immediately changed out all the parts, as you do. I had to have her different from everyone else cuz I just can't stand to be the same. :drama: That and that brown looks like a bad poop color.
Mostly original with a few things swapped out, stem went immediately as it was just way too long and the bars were way too narrow.
Don't care about you Fox haters, those forks were amazing and only changed so I could have a 20mm front.
Changed out a few more things... Went single ring with an amazingly priced guide, got new wheels/hubs/nipples, and got a Lyrik. Not sure where those tires excel, but it's not Sydney...
This was one of the most fun experiments. Love the pedal, wanted to be different. After speaking with Nukeproof for quite some time about whether or not the pedals would stand up to being dyed we just went for it. They're a nylon composite which is similar to a lot of R/C wheels, we already knew those could be dyed quite easily and very well. The only difference is the R/C wheels can be dyed at high temperatures and we weren't so sure with the pedals. So to play it safe we kept the dye bath a bit less than boiling.
Finally after months of talking about it, we finally painted the ol' girl. Except it was Plasti Dip. The color is not quite what i had in mind, I was wanting a darker green but this was mostly an experiment to see what would happen! The dip is quite easy to use if you use a lot of spray paint, which we do, but it would really take several attempts to get the technique correct I think. It comes out of the can in a VERY wide spray compared to regular paint, and it's plastic...so it's kind of blobby. The small surfaces of the bike frame give it an odd "fuzzy" texture in spots. It's best coats are on the wide bits. This was done without removing the ano finish, cuz you don't need to really and I was hoping for a bit of a metallic bleed through. Didn't happen. This is 4 coats on all the parts. The last coat was done quite heavily with the green and rather light with the purple. I'd go heavy on the last coat next time, it's pretty much all filled in by that point and it seems to give the dip a better smoothness. We masked the components as Plasti Dip doesn't hurt them, and masking is a whole lot easier. So, suck a dick ?
Haven't ridden it yet with the new color, not sure on durability. Originally was/still am going for a 90's Batman: The Animated Series Joker look. You know, the good Joker voiced by Mark Hamill... Stickers may be applied depending on how well the Dip holds up. We used the BLAZE range of colors which are the bright, or hot colors. $30/can from Autobarn
Frame - 2008 Reign 1
Rear shock - Fox RP2
Front shock/fork - 2011? RS Lyrik 160mm
Handlebars - FUNN Fatboy 750mm
Stem - FUNN Strippa 45mm
Headset - FSA
Grips - Lizard Skin Logo
Saddle - WTB Speed She, a girl one. Or a Big fat DMR jump one.
Seatpost - Raceface something or other, and a massively shortened one for less sitting down tracks
Seatpost Clamp - Blkmrkt, close up it's got speed holes that show the green thru it's pretty cool.
Front brake - SLX w/200mm
Rear brake - SLX w/185mm
Cranks - Hozfeller single ring 36T
Chainguide - E13 LS1
Pedals - Nukeproof Electron, custom color
Rear derailleur - SRAM X9
Rear shifter - SRAM X7
Cassette - Sram something
Front hub - Nukeproof Generator
Rear hub - Nukeproof Generator, 6pawls...I was curious and already have a Hope.
Wheels - Rhino Lites with DT to Primo, green and purple
Tyres - Ardents 2.25
Tubes - Accidentally sent ones that ended up being free, they are super light tho.
Total weight - Less than me, good enough.
Headset - FSA
