Having cut steerer tube for my bike on new forks as well as on old hand me down forks for my kids bikes and truthfully, as long as you don't cut it too short it doesn't really matter much.
As long as the angle is close to what you can see as straight by eye it will be fine. If the star nut is pretty straight it will be fine. A cruddy old hacksaw will get through easily too. Basically there is quite a bit of tolerance so its hard to really screw up.
HOWEVER, if a jobs worth doing its worth doing properly. Use something to make sure the cut is straight (skill or some kind of mechanical guide) and then file or sand it down so its not sharp (an aluminum filing splinter later on is annoying). Make sure the star nut is straight and moved clear of your cut before you cut.
But MOST importantly measure and measure again... and then again, and maybe one more time, and again. Just to make sure you are cutting it to the right length.
