Dealing with a sandy slope
ss-stp1'06
hello to all
me and a couple of friends have a trail, and there is a part which is quite a steep down hill...and the trail goes inbetween a couple of bushes and a tree, and then theres a drop off a rock onto more downhill...
now this would not be that much of a problem...except there is a corner leading into the drop, and it is very sharp. Also its made of sand...we tried digging it out...but it just kept comming and comming. Just wondering if there is anything that we can do to the sand to make it ride-able..:confused:
thanks
Maybe shove tonnes of rocks over the sand, so no more is visible. Then pile dirt over it. Rocks will keep the sand stable.
do what they did at a top riding spot in sydney.
maybe if you pour gallons of water on it, it may become ridable?
add some cement to it to hold it together (ie. to make it harder but not a super hard solid thing) then maybe add some dirt ontop?
does grass grow on sand?:confused: :p
Yea Buffalo "shack" grass will, you need roots in the sand to hold it together, otherwise you need to spread the loads from your tyres so you don't bog down in it, you could make a timber ladder bridge and half burry it so it doesn't move, or tile big flat rocks in there like pavers.
It sounds like bad trail design. A boggy corner before a drop off is just begging to hurt people as they will often come out of the corner off balance. You said it was steep, so contour the track away from that area.
marty i think we've decided to give up on that trail, it just way too tight and technical plues there is NO WAY that we can move that tree
we wernt planning on moving that massive tree!:p
im just getting ideas...and if one day its all raining and stuff we can go there and fix it up
it might sound dumb but you can put old carpet over it. like they do on home made 4X tracks. this will hold the sand in place and stop you sliding as much.
I dunno if this would work but would smoothing out the sand and compacting it as much as possible and then get you hands on some chicken wire and lay it over the top and bolt the corners down some how. I would imagine it would grip your tires nicely but maybe to much.:rolleyes: And if you fell off on it well thats another story in itself. neway just an idea.
chris
build a north shore over the top of it all, this is exaclty what therye designed to conquer. or you could put mesh or old fence mesh over the sand, yes you will still have to ride through it but there will be a solid feeling of grip underneath you.
Considering sand is very efficient at draining I doubt putting water on it would work. (Hey look at the beach!) As stated before it sounds like bad trail design, building North shore is a ridiculous idea unless the drop is exceptionally fun to ride as it is most likely you will end up with nothing but wood scraps in sand.
Yeah, i think that if you cover it in dirt and then possibly plant some grass or something similar if you feel you need to, rocks wouldn't be a bad idea.
i have found a wicked 15 foot stepdown off an old lookout but its onto sand, im guessing i should just wait for a good session of rain before riding it??? cant think of anything else, at kleast the sand will stop me softly if i come unstuck, might try carpet though
