No issue with mounting a fork with disc mounts on a bike that didn't have disc mounts, no adaptor required...but I suspect that wasn't your question...Is it possible to get some kind of adaptor to mount a disc mount fork on a rim brake bike?
Hope that makes sense
Ers
So a disc compatible shock will work on a rim brake wheel/frame?For a fork, easy, just fit a disc compatible fork.
For converting a non-disc frame, get friendly with a framebuilder.
Forks and shocks are at different ends of the bike, I assume you are talking about fork. The reason it says 'disc only' is because it doesn't have mounts for rim brakes.So a disc compatible shock will work on a rim brake wheel/frame?
Some shocks say disc only, why is that?
Thanks
Ers
Ahhh, so my original question (that I thought was unclear) was what I needed to know. Can i mount rim brakes on a disc fork via some kind of adaptor?Forks and shocks are at different ends of the bike, I assume you are talking about fork. The reason it says 'disc only' is because it doesn't have mounts for rim brakes.
No...I am sure somebody makes some really crappy adaptor but no.Ahhh, so my original question (that I thought was unclear) was what I needed to know. Can i mount rim brakes on a disc fork via some kind of adaptor?
Thanks
Thanks 10 charsNo...I am sure somebody makes some really crappy adaptor but no.
Wait, what? Dear god I hope not. :fear:Can i mount rim brakes on a disc fork via some kind of adaptor?
Thanks
Sadly yes. A m4 low tensile set screw is going to have all the clamping force of a wet noodle.....Wait, what? Dear god I hope not. :fear:
Yes, I read it as wanting to add brake bosses on a disc fork. THATS the part that scared me :fear:Sadly yes. A m4 low tensile set screw is going to have all the clamping force of a wet noodle.....
Getting serious here for the original poster.
Our combinations of answers here:
Rim braked wheels have nowhere for the disk to bolt on. The above adapter is a joke.
Disk only forks have nowhere for the rim brakes to attach too.
Rear disk brakes can be added to the frame with adapters, but again you need a disk compatable wheel.
Rim brake adapters onto a disk only fork, there probably is an adapter but most forks are too thin in tube sidewall thickness to take the loading
Maybe? That's 2 then.Thanks for the replies.
Maybe this should be moved to the stupid questions thread
