DMR rhythm rear disk brake?
jakestein
will a rotor fit stait onto the hub or can i put the one off the front on the back as i dont really need it?
thanks
ok so being a dmr unit it should? if not get an adopter or a new hub i guess thanks
this board is great for getting ya info fast!
just go have a look at it and see if it has 6 screw holes in the side of the hub witch the brakes go on
I might of missed something here, but why would you want to run a rotor on the back and not on the front?
Cos it's more hardcore to run into stuff because you couldn't stop in time.
thats a disc (front) hub, and
thats a non disc (rear) hub. if you have the above hub, you can get an optional disc mount to screw on
well i will use it for dirt jumping and i dont need a brake on the front.
it will need an adapter and locknut about 50bucks so thats ok
I really don't understand the point of that rear hub. I have heard of a lot of street riders who have tried to use it but say that it's crap, because if you grab some brake going fakie, you can unscrew the adaptor. Why not just put on the IS mounts?
