After a few years off the bike I decided to rebuild ye olde Sunday. Tried to keep it on a mostly budget build but that didn't work out so well...
Frame - 2006 Sunday
Rear shock - 5th Element - Had the old SPV guts scooped out and replaced with a shim based damper by Tekin
Front shock/fork - 2015 Dorado Expert - With TSR relief caps and IRV added to the spring for extra fun times
Handlebars - Funn something or other
Stem - SIC integrated job
Grips - Intense
Saddle - Old SDG I beam, reupholstered in black leather.
Seatpost - I beam
Front brake - Saint/SLX lever, only because the latest dorado incarnation has direct 8" post mounts, I had my old xt 4 pots all lined up with new servo wave levers, but IS mount caliper just wont work
Rear brake - XT 4pot, SLX lever
Cranks - zee 165
Chainguide - Funn Zippa
Pedals - Atomlab Aircorps
Rear derailleur - Zee DH
Rear shifter - Saint ispec
Front hub - Dice
Rear hub - Hadley(close to 12 years old)
Front rim - 521
Rear rim - 521
Tyres - Minion DHF
Recycled as much as i could off the old build, need to get some new wheels built, rims have both seen better days and something tubeless ready would be better.
Saint brake works well enough but the old xt caliper does out perform it. Far more consistent feel. Dorados feel excellent, needs to get a few more runs into it to break them in properly, then can start getting the pressure in the IRT and the main chamber balanced out for fun times.
Frame - 2006 Sunday
Grips - Intense
Seatpost - I beam
Cranks - zee 165
Front hub - Dice
Front rim - 521
Rear rim - 521
Tyres - Minion DHF
