udi
swiss cheese
Believe it or not, with a thread title like "Dremel - better cutting discs?" my question was actually in regards to the best cutting discs for a dremel, not "I'm unsure of which tool I need to use, please help me decide".
Not trying to be a dick here and thanks to those that offered useful suggestions. If you really want to feel at ease that I'm not jumping to the angle grinder or hacksaw when I could be, the specific times I use the dremel are when I am trying to do something where those tools won't work. An example is cutting non-circular holes, usually in aluminium, of a size where an angle grinder would be far too large. Imagine cutting a ~10x20mm slot that is not neccessarily rectangular (eg. could be a chamfered parallelogram) with an angle grinder - it's just not happening. Being so small as well as "blind" also makes it pretty difficult to use a hacksaw.
This isn't for one particular job. Unfortunately this time the material is 7075 series and it's taking too long as a result which is why I asked about heavier duty discs - anything capable of cutting mild or stainless steel will get through the high grade aluminium too.
http://www.rotorburn.com/forums/sho...anchion-Wear&p=2831698&viewfull=1#post2831698
Thanks, unfortunately what I'm trying to cut is quite small which necessitates the use of the dremel until such a time when I can purchase a milling machine, which would be the correct tool for this job. I will give the wax a go, sounds like it will help. As above what I'm trying to cut is usually thin aluminium (2-4mm thick) of varying grades (usually 6061, occasionally 7075 which is a struggle for the dremel). I'm pretty sure there are better quality abrasive discs out there than what I'm using however - hence this thread.The high rpm of a dremel is going to generate a lot of heat which will in turn cause the aluminium to "pick up" and build up on the cutting wheel , which then goes into snowball effect.
Agreed on all counts - I am only using the dremel in instances where it is physically impossible to use hand tools (or quite impractical / even more time consuming) and too small a job to use a proper grinder. I have the benefit of the corded version so it's just the cool down time to deal with though.I have used the EZ lock discs for a while. They haven't shattered (yet) like the stock discs (my eyes are grateful) but they aren't much chop compared to a proper grinder. To be honest I go for hand tools for cutting unless it's big enough to get the grinder on. I'm no genius, but I think the Dremel is just too small a tool and overheats really fast. Forever stopping to let it cool down, interspersed with needing to charge my cordless version.
I am impressed by your vast credentials, but let's try and figure out the basics before worrying about giving me advice shall we?Well, there's six people in this thread advising you not to use a Dremel. Maybe if you provide us with a bit more detail on exactly the job you are trying to accomplish, we might be better able to advise you on the right tool. I raced cars for 10 years, I've spent a lot of hours and a lot of $$ on aluminium fabrication, and still got most of the tools
My secret is out! Please name this guy so I can get my patent lawyers onto him!He's making a hucking kitty out of wood.
