SideFX
Dose a DT SWISS tubeless rim have to use DT SWISS tubeless valves ? Or can any vaulve do . I'm getting a poor result in s tubeless set up with a tiny amount of air leaking from the bass of the valve . The rim is s DT 570 , its tubeless ready . The rim has a rubber grommet around the valve hole , I've keepet that there , inserted the tubless valve and screwed the valve nut down tight. But a very small amount of air is coming out . It's not major and I can live with it but I've had better results .
