I don't think you can convert that way? Could be wrong mind you.I have the ones that allow you to put 6-bolt rotors on DT centre lock hubs - but I think you’re after the opposite?
I concur.I don't think you can convert that way? Could be wrong mind you.
Sent from my SM-G955F using Tapatalk
Nope, the ones you have is what I'm chasingI have the ones that allow you to put 6-bolt rotors on DT centre lock hubs - but I think you’re after the opposite?
Send me a pick chigsBtw, I have one of the adapters that converts CL to 6 bolt. Nfi what brand. Yours if you want it.
Let me know if you’d also like a pic.Send me a pick chigs
Got these adapters with a set of DT Swiss wheels and while they are clever, I'm curious to see how they'll last. Those 6 aluminium posts may wear quicker than a traditional bolted adapter like a Shimano RTAD05. I'll happily stand corrected though, just haven't done enough miles on the wheels to see just yet....
Also might add that just now did I realise how they actually work in securing a 6-bolt onto the wheel...clever!!!
Can’t say I’ve seen those. Kudos.View attachment 342030
Despite Moorey and JT’s best efforts to undermine me, this is what I have.
Does that suit?
The ones pictured have probably 900km on them and don’t seem to have worn at all.Got these adapters with a set of DT Swiss wheels and while they are clever, I'm curious to see how they'll last. Those 6 aluminium posts may wear quicker than a traditional bolted adapter like a Shimano RTAD05. I'll happily stand corrected though, just haven't done enough miles on the wheels to see just yet.
These bad boys will last you years and years Nambra, I've had them come loose during a rideGot these adapters with a set of DT Swiss wheels and while they are clever, I'm curious to see how they'll last. Those 6 aluminium posts may wear quicker than a traditional bolted adapter like a Shimano RTAD05. I'll happily stand corrected though, just haven't done enough miles on the wheels to see just yet.
If DT Swiss were a woman, she'd be the last one to be kicked out of bed come the morning.In my eyes anything DT Swiss does wheel wise is amazing
I meant conversion the other way isn't possible.View attachment 342030
Does that suit?
Thanks for the feedback, good to know it's just me overanalysing as usual...These bad boys will last you years and years Nambra, I've had them come loose during a ride
(due to my own fault) and get finger tightened and they're still going strong years later...
That is also what I meant, however, I’ve not seen those and still can’t picture how they work.I meant conversion the other way isn't possible.
You can't go CL rotor to 6 bolt hub.
