Wollongongrider1234
I raced a set of recons on a hard tail at a dh race. I was lucky to complete my race run because mid way down the recons started to deflate. Whats the problem and how much would it cost to fix the forks?
They're fucked and ask http://www.nsdynamics.com.auWhats the problem and how much would it cost to fix the forks?
I wouldn't say that they're either high-end or all-mountain, I'd probably call a mid-range trail/XC fork. Either way, Recons shouldn't be used for racing DH, especially on a HT, and we can't really diagnose OP's problem w/o more info. Sending them to NSDynamics is probably going to be your best bet if something serious is wrong with them.They are a high end all mountain fork. Probably not what you want on a hardtail when racing DH.
it was a long drawn out deflation - from pumping them up to my correct pressure for my weight they went down completely within about 5 or so minutesVague question much.
How old are the forks? When did they deflate? What kind of deflation (Short and sudden loss of pressure / Long drawn out death?)
Any other related information about the issue etc.
If you want reasonable and concise help from people you need to supply appropriate details to aid their evaluation of the situation.
Otherwise. Flamesuite is the only option.
Dude thats what i got!!!! The reckons are just sitting under my bed and i want to start using them againIIRC a RS seal kit is around $55rrp.
The real solution to your problem will cost $499rrp and is called a set of argyle coils.
You will have to rebuild your forks every time you race DH if you don't get something appropriate. You are probably also risking injury riding a generally inappropriate bike.
