Heyo
Im going through the process of upgrading the fork on my runabout '13 Specialized Rockhopper 29er.
Currently it has a suntour xcm 1 1/8th non tapered, with an apparent 'reducer'.
"1-1/8" w/ lower bearing reducer, Campy style, integrated full cartridge bearingss"
http://www.specialized.com/au/en-au/...opper-29#specs
The head tube appears tapered and the pro model comes with a Rockshox Reba (1 1/8 to 1.5)
What bits and pieces would i need to fit a a rocksho Reba (tapered tube) into the frame? This reducer business... i dont like it.. is it just a bush that i can pop out and the new tapered fork will bang straight in? Will i need a new crown race? will i need a crown bearing sized to fit the tapered tube? or will the existing bearing work with that reducer thingymebob removed?
Im fairly noob to all this campy integrated stuff, and would like to diy as much as i can before taking it to the LBS. Or is this something that an LBS should do rather than a ham fisted individual like myself?
thanks!
thanks!
