or you could just let all the oil out and run them oil-lessAirDog said:is the leak from the join of the leg and the arch ? if so rmove the oil in that leg. remove the brake boss (un screw with 9mm spanner i think) hold the leg tap the arch up with a mallet a bit to seperate. clean well with spirits .. and put some silicon around the arch(should have bushing in it still to stop silicon going inside leg) join them back together tighten the boss back up and leave to sit for 12hours go around the outside with a sharp knife to remove any silicon ... don't pull it or you'll reck the seal you just made then add new oil and you should be right.
andrew said:or you could just let all the oil out and run them oil-less
andrew said:my air fork worked with pretty much no oil! it tops out to the fat, and has no damping but apart from that mine was fine![]()
true. but they were goning to die some other way before they wore out. creased stantions nowwombat said:andrew said:my air fork worked with pretty much no oil! it tops out to the fat, and has no damping but apart from that mine was fine![]()
Emphasis on "WAS fine". It would probably be alright for a while, but one of the principal functions of the oil in a fork is to act as a lubricant. Running them dry is just going to kill all the parts where friction is present.
