wornoutwords
Item: 27.5 160mm pike debonair shaft (the B1 upgrade for the A1 version)
Price range/Willing to Pay: 20-30$?
Extra Info: want to try it out to see if it improves the small bumps.
trade bait listed below
I think i can just use the foot nut and top if it's a different size? Prefer the older B1 version rather than the newer C1 as the older was a bit softer
Item: short stack stem. <=30mm height, 30-40mm length. 31.8mm
Price range/Willing to Pay: less than new/depends on what it is? I'm not picky though
Extra Info: trade bait listed below
for trade +/- $ depending on what you got and how well you know it
* sram rear maxle lite
pn: 00.4315.015.020 (i think)
Size:
142 x 12mm - 174mm Long - M12x1.75 Thread 20mm Long
comments: only had it on the bike for a few days - the handle interferes with the frame so I got a cheapie ali express stealth axle instead. No damage to the cutout thing because I couldnt use it for doing it up - but you can use a 6mm hex wrench up the thread end to do it up
* xt 11sp derailer
comments: parts only - it's bent. The cage hits the bolt that holds the cable down
* sram gx 11sp derailer + shifter
comments: parts only. i thought it was ok, but seems its lost a tooth off the bottom jockey wheel
* xt 10 sp cassette (11-36)
cs-m771-10
comments: good
Rockshox Air Spring Upgrade Kit Pike DebonAir 2014-2017
Genuine Rockshox Air spring upgrade kit for Pike Solo Air 2014-2017 (35mm) Not suitable for DPA Pike. kit includes DEBONAIR shaft assembly and updated seal head. Available in several options for all 27 and 29" wheels. Includes the main air piston, seal head and seals Increases negative air...
cyclinic.com.au
Size:
* xt 11sp derailer
cs-m771-10
comments: good
