There’s no such thing as a Zee medium cage.Item: Zee rear mech medium cage
Item Condition: Working
Reason for buying: need one
Price and price conditions: they are $70 new
Thanks mate, yep wide range not mid cage getting my words mixed up.There’s no such thing as a Zee medium cage.
There wide (up to 36) and close range (up to 28), but they’re the same cage.
I had varying success with 36t on the wide range. On some bikes it struggled more. Better off going XT middy if planning to run more than 36.
Will check tomorrow if I have spares of either.
Don't suppose you would have a SRAM 9spd shifter kicking around would you?There’s no such thing as a Zee medium cage.
Go back and look again....Don't suppose you would have a SRAM 9spd shifter kicking around would you?
Ah sorry mate was hoping I cought you before you went looking.Go back and look again....
Yep going to try a @SummitFever special on the Honzo.You’re doing a 9sp clutched setup, I assume?
Got one that’s on the 222 in the rafters.
Looks straight, was sweet when last ridden years ago, lower jockey is a bit worn, but don’t have a good spare.
I did a thread. I’ll hunt it down. You can have the home made spacer on mine. Not as pretty as Georg would do.Hmm didn't know one was necessary but also have not researched this a great deal was going off the info on faqload.com but hadn't looked further.
That would be great thanks mateI did a thread. I’ll hunt it down. You can have the home made spacer on mine. Not as pretty as Georg would do.
