Its worth noting that 09 32 forks will have a 15mm through axle option which will require a new 15mm hub standard. Im interrested to see if the current 20mm hubs can be used via some sort of 15mm adaptor.Also, note that Fox 36's have 20mm thru axles while Fox 32's have quick release axles.
I ride trails and light all-mountain stuff on my Giant Reign and ride a set of 32 Floats. I can't really fault them. They are simple, light and have great adjustability. If I was focussing more on my Downhill I would consider getting 36's (but by that time I would want to get a separate DH bike and not compromise on a light trail machine, being the Reign with 32's)
Yeah, it will be interesting to see if there will be adaptors for the new 15mm thru axles and 20mm hubs.Its worth noting that 09 32 forks will have a 15mm through axle option which will require a new 15mm hub standard. Im interrested to see if the current 20mm hubs can be used via some sort of 15mm adaptor.
I have a 08 Reign which came with a 32 Talas RLC which was really OK for the style of bike and my riding skills. Recently I fitted a 36 Talas in the quest for "one bike does it all" thing.
Although I like the effect on the handling due to the ( slackened head angle) I think it is a bit of a compromise. The 36 does get me down the mountain on shuttle days and up the mountain for cross country rides but Im finding for normal trails that it is way more than I need and its not supple enough for technical down-hilling. For more full-on riding I think the Float and Van versions of the 36 are are better bump gobblers. For cross-country trail riding I really love 08 Float 32.
32s are really more than up to the task of eating terrain for most trail riding for most people.
I like Talas alot (I ort to as I have two) but I think it depends on the bikes handling traits and your riding style to weather you engage the Talas or not. My old bike, an 08 Reign, had me wanting to drop the forks on steep pitches while I dont touch the Talas nob ever on my new Blur LT.If you tend to focus more on XC/trail then the 32's might be better. Despite the lack of suppleness of the TALAS models I would seriously consider them. My 32 Floats have 140mm of non-adjustable travel. They are that light and tall that keeping the front wheel on the ground up steep climbs becomes quite difficult (you really have to concentrate on leaning forward and getting the elbows out). I'm quite sure a wound down 36 TALAS would climb better despite being heavier.
But, with the new 32's coming with a 15mm thru axle, they will offer a lot of what the 36 has to offer with stiffness, but obviously not as much travel.
