bared 4 life
what fork should i get fox 4os or boxer world cups
That is so trueThere's been many threads on this, give it a search. I'll summarise though.
Holden or Ford.
So how do the Boxxers with the Elka cartridge compare to the 40s I was thimking along the line's of getting a set of teams and putting a Elka cartridge in or do you think the 40 would be better cheersComing from an ex 40's owner and now a boxxer wc owner (now with Elka cartridge).. 40's are lightyears ahead of the standard boxxer!
Ah yes, this guy knows where it's at these days ^marzocchi evo ti 888
I have ridden BOS idylles given only a hand full of times and it was set up for a slightly heavier rider than myself but the forks were a msssive let down. They were not as frictionless and did not track as well as I expected, I am not the only one I know who has been less than impressed by the forks. I would take boxxers, 40s or Marz over the bos from my experience any day.This is a hard topic to actually say anything about for me, having not tried either. but it does seem to be a topic that is a holden/ford battle(Holden For THE WIN!). just to put them side by side though. the boxxer is air sprung, has skinnier uppers 35mm and offers beginning/end-stroke rebound, high/low speed compression adjustments, and then preload and air volume adjustments. the fox 40 is coil sprung, has a larger 40mm upper (which it's named after) and the rebound, high/low speed compression and preload. the boxxers have "low friction adonising" while the fox 40's have kashima coating (smoother).
aside from that all i can tell you for sure is that you will get less twist in the fork legs with the 40's, but not as much adjustability. you will get a smoother feel with the kashima coat than with adonising, but the boxxers are lighter. it's just another holden/ford thing
just go BOS idylle RaRe!
There a big step closer.. but compared to the new 40's there still not there.So how do the Boxxers with the Elka cartridge compare to the 40s I was thimking along the line's of getting a set of teams and putting a Elka cartridge in or do you think the 40 would be better cheers
