fox floatx2
mtn_bike_geek
Super Moderator
I actually don't mind the Float X2 riding up. If set correctly following the guidelines, low speed bobbing is relatively minimal. I can only imagine that the Climb Switch will improve on that further.
single-pivot
shock
Post short ride report.
After swapping rockshox monarch debonair plus out .
Set recommend sag setting.
Then dialed in hs,ls.hr,lr settings as per guidelines
Climb switch is cool as it moves 1/4 turn one way was like riding a hardtail other is full open then anything in between is cool for rough up Climbing .
two
Ride was cut short due to some storm damage closed access, so hit old drops track plus some fire trail.
Big hit drops where a breeze ,fire road was nice .and poppy .Adjusted Ls to 20 out ,for chatter bumps when i got home.
So very much impressed so far
Still need more personal tuneing.
Otherwise is filling expectations
