fox forks
ollieo
Fox Forks .. I had what I thought were 160's but not ab sure . I have 160 from seal top to where stauntion meets the chassis.
Rock shock don't seem to make any distinction between 150 and 160 .. an extra piece of red plastic to change .. is it similar with Fox..
Thanks for any illumination
Ollie
34's... question is ... is the distance, seal top to top of Staunton the fork length .. not much between 150 and 160 ... fork pushes the rubber ring up fully..
Fox don't nominate fork length on the product.
160 fork should have about 167mm between top of wiper seal and the crown.
If you have less then you could have either a 150mm fork or your ideal air pressure isn't enough to fully extend the fork. Try pumping more air in it and see if fork extends further.
