First track ive spent time on, its a current work in progress here it is though
-18 1i 18 1i,3c 1v 61 2e 7o 2g 9m 2l bg 2j ct 2j dt 29 f0 1q,ev 1q fb 1k fi 1g fp 1e fv 1e g5 1g g7 1j g8 1q g8 2j gn 2m,go 2m h4 2r hb 31 hp 37 i3 3b ic 3d ik 3d is 3g j4 3g,j3 3g jd 3h jj 3l k1 3o kc 3r kk 3q ko 3q kt 3r l0 3t l6 44,l6 42 lg 4u m2 5f mh 5u n4 5s nn 67 ou 75 po 77 ps 7c qi 7e r5 7c rt 7a s8 77 sd 75 si 75 sp 76 sv 7b 103 9n,19n h8 1a5 hi 1af hm 1ar hr 1b8 i0 1bg i0 1c2 i4 1cg i3 1d8 i7 1dp ii 1ei ik 1fe il 1fq il 1hn ie,1hl ie 1ht ie 1im ig 1iu ik,1iv im 1l2 kl,1l3 km 1ln l6 1m6 lb 1mt lh 1ph n1 1q0 n8 1q9 ng 1qd np 1qd nu 1q9 o3 1ph p0,1qb o0 1ql o5 1r2 o7 1rc o8 1rh ob 1rj oh 1rl oo 1rd pf 1r4 pm,1rl om 1rt os,1ru os 1s8 ou 1sn ou 1su ov 1t3 p3 1t7 p9 1ta pe 1t8 pn 1sr qc,1t9 pl 1tl po 1uc pu,2j7 18c 2oe 187 2p7 18c 2pk 192 2pk 19p 2q0 1ap 2qp 1ce 2qu 1d4 2qp 1ea 2qk 1f0 2qn 1gi 2qp 1hl 2r8 1i9 2rl 1j7,2ri 1j7 2t2 1l8 2te 1m6,2th 1m6 2u7 1o5 2uf 1qd 2uf 1rl,2uf 1ro 2uf 1st 2v3 1ua 31b 1vq 34a 20l 3e2 22q,3ia 1v5 3p5 253,3p4 252 3sn 284,3sn 283 3t2 28a 3th 28j 3u1 28r 3ud 28u 3ut 292 3va 295 3vm 298 402 29a 40c 29a 40q 29b 41d 29a 41n 297 41s 295 428 294 42h 296 437 29m,438 29o 43n 2a4 44l 2b1 44q 2b4 452 2b9 459 2ba 45q 2be 462 2bk 465 2bp 46b 2c8 46g 2cc 46n 2ce 470 2cf 47c 2cf 47j 2ck 47u 2ci 483 2cl 485 2cp 48i 2cs 48s 2cs,4a8 2dg 4do 2gi,48t 2cs 493 2d1,492 2d0 49e 2d4 49p 2d8 4a8 2dg,3ia 1v5 3h7 1u9,3h6 1u9 3h1 1u5 3gq 1u2 3gf 1u1 3g9 1u2 3g4 1u4 3fu 1ub 3fq 1un 3et 22r,3e2 22p 3et 22s,1ua ps 1uj q7 1us qj 1ut r6 1v1 ro 1v1 s7 1v7 so 1va tc 1v6 tg 1v6 ts 1vj ui 203 ur 20m v3 21n vg 21p vq,1v0 s6 1up ss,21n vq 21r 111,21q vq 22m 10b 23c 10i 242 10v 24k 113 258 11b 25f 11h,25f 11e 26f 127 273 130 27d 13u 281 14g 28v 15g 29j 16e 2ap 175 2c8 17u 2e2 188 2fp 188,2fu 188 2jm 18a,4do 2gh 4fu 2i3 4i7 2j8 4ku 2k6 4nr 2kg 4rg 2ko 4vq 2kl 55q 2k4 582 2ji,585 2ji 5go 2go 5l4 2f6 5mu 2eq 5nu 2ev 5ov 2fj 5ve 2pl,6mk 30o 71d 3bk,6mj 30p 6m2 307 6le 300 6gl 2vt 6fs 2vo 6fg 2vc 6f1 2vm 6dp 2vo 6ch 2vm 6c9 302 6bj 30m,6b9 30m 6a1 30f 69f 30p 67t 313 65n 30c 656 2vh,653 2ve 63m 2v7 62r 2ts 624 2t8 61l 2ru,61l 2rr 60g 2qo 5va 2pg,6b8 30m 6bi 30m,18 1h 3c 1v,-19 1j -2q 1i,101 9m 19m h8,71d 3bi 739 3de 74c 3em 75f 3fh 76k 3g3 781 3gp 797 3io 7am 3k0,7am 3k5 7b0 3m6 7c8 3nb 7dv 3oc 7gs 3ph 7ja 3r3 7m6 3sn 7pg 3th 7rs 3th 7ug 3sv 818 3s7 82m 3rf 84c 3rj 88e 3pv,7al 3jv 7an 3ka,-ef dh -53 2o -4h 27 -3r 1o -2e 1j,-ie g1 -nc go -tr gv,-im g1 -ec df,-2q -1p 1k -1r#-17 1j -2j 1h,-ed dg -id g1,-ek 7f -ek 7l,-2k 1g -30 12,-2k 1g -2g 10,-2l 1f -2n 14,-28 1h -2c 18,-28 1f -20 18,-27 19 -26 1f,gj 2q go 2q gs 2s gv 2t,ge 2u gh 30,hj 39 hp 3d hu 3e,j0 3j j8 3m,ki 41 kn 41,kq 41 ku 43,kv 4d l0 4l,jo 3q js 3r,jk 47 jr 48,fb 1j f7 1o f2 1t ei 27 ds 2g dd 2l d0 2m c0 2k,lp 5e lv 5g,m0 5p m0 5t,ld 58 l6 57,nd 68 ni 6a,mv 60 n3 60 n7 61,pd 7b pk 7b,o3 6o od 6v,no 6h np 6q,ri 7g rs 7g,sa 79 si 7c,sp 7e ss 7k,qt 7j r6 7i,5h 28 5h 1d,5h 1k 7b 1m 84 1n 9g 1o,al 1p bn 1p cr 1k e8 19,e7 19 fb p fc 1h,i1 2a jj 2o ki 2u,of 5o pn 64 r2 6a,pr 64 q0 65,s1 67 st 6d tn 6p 19l g2 1am gk 1be gr 1d3 h9 1e3 hb 1fl he 1h7 he 1i6 hf 1io hj 1je i0,1jf i0 1m1 k7 1n3 kg 1qf md,1qj md 1rf nb 1sd nl 1t5 ob 1u9 oi 1v4 pe,1v4 pg 1vn q6 209 sc 20f tn 20q u1 25i 10g 26n 119 27i 126,27j 126 2ad 15o 2bv 16o 2cj 171 2fe 17e 2od 17e,3hi 1t9 3t5 275 3u8 27q 3vl 286 40u 285 40u 298,i1 2a hq 35,9f 1n ao 1p,kh 2t l6 34 lj 3i lt 4e mh 53 n3 59 on 5p,r0 69 s3 67,2od 17d 2p5 189,3hh 1t9 3h2 1u3,-19 1i -2n 1h,9h 1o 9h 2k,mi 53 mg 5r,sk 6b si 72,11p 9v 11d am,16t du 16b el,1ck h5 1ci i1,1ja i3 1iu il,1o2 l2 1nf lp,1qh md 1q2 n7,1v5 pe 1uc pt,20p u2 1vn uj,23j vf 22o 10a,28o 13k 27m 146,2dc 174 2cv 182,2jg 17e 2j8 188,11g ap 11f aj,11f ao 11k an,11e ao 11i ah,120 b5 120 av,11u b7 124 b5,124 av 11t b5,13p cg 13r c9,13t ck 143 cf,13v ce 13r ch,13p cg 13r cj,12s bv 12s c8,1fu il 1ge in 1h1 it 1hh iv 1hu j3 1i8 j9 1ih jb 1ip j9 1jf j7,1i5 in 1ig iq,1ip iq 1ir it,1hf im 1hs ir,1qf ob 1qr of,1r4 of 1r9 oi,1r9 or 1r3 ot,1sb pa 1si ph,1s0 po 1s9 pt,1tq q7 1tv qm,1uh qs 1ug r6,1tv rs 1tp s0,1v2 su 1ut t0,1vd v3 204 ve,210 vg 219 vk,240 10v 23f 110,4rj 2jg 4rh 2km,4rj 2jg 4m6 2j6 4m4 2k7,4m5 2jb 4ri 2jm,4m7 2j9 4ri 2jj,4m5 2ji 4ri 2js,4m5 2jo 4rg 2k3,4mc 2jn 4mo 2jo,4oo 2jr 4p6 2js,4q6 2jt 4qq 2jt,4r1 2ju 4rc 2ju,4m4 2k2 4rg 2kd,4m5 2js 4rg 2k6,4m8 2k0 4mh 2k2,4mb 2ju 4mk 2k0,4m7 2k0 4rh 2k8,4rg 2ka 4m8 2jv,4ri 2kc 4m4 2k0,4m5 2jt 4r9 2k7,4rg 2ka 4m5 2jt,4rm 2kn 4rv 2k2,4rv 2j3 4rr 2j1 4rp 2iu 4rp 2ik 4rv 2ie 4s5 2ie 4sa 2if 4sd 2ii 4rp 2im,4rv 2j3 4s5 2j1 4sb 2iu 4sc 2iq 4sd 2ii,4s0 2jb 4se 2j3 4sh 2is 4so 2is 4so 2ij 4sf 2ik 4sg 2ir,4rv 2jb 4sf 2j7 4sk 2iv 4sk 2is,4sc 2ii 4sn 2ie,4so 2il 4ss 2il,4sn 2ip 4sq 2ip,4sr 2iq 4t1 2ir 4t0 2ik 4sr 2ik 4sr 2iq,4t3 2il 4t8 2il,4t2 2ip 4t8 2ir,4t5 2in 4tb 2in,4t3 2ik 4t6 2ih,4t3 2ir 4t7 2it,4rv 2j2 4s0 2k1 4sd 2kl,4uv 2n6 4v1 2mv,-2o 1g -2p -1p,1k -1q 1j -28 -2n -40 -4q -41 -4o 2c,-4o 1l -3o 1l,-4o 17 -2q 16,-4o l -2p l,-4p 7 -2p 6,-4p -8 -2p -8,-4p -s -2q -s,-4c -k -46 -k,-3n -d -39 -e,-4e 0 -44 0,-3l 0 -37 0,-3o f -3f e,-3u v -3j t,-41 1e -3q 1e,-33 1c -2v 1c,-4k 1b -4g 1c,-4k 1u -4f 1q,25b 120 25o 125,25u 12d 267 12s,234 11u 23e 12b,285 15f 28d 15q,2an 17n 2bc 187,2m8 191 2lm 19j 2lj 1a6,2mv 1g0 2mg 1hi,2m1 1et 2lm 1fa,2l7 1fv 2l3 1g9,2l4 1h9 2m2 1is,2qa 1lj 2pu 1mp,2pb 1bd 2pb 1c8,2q9 1cm 2po 1dt,2pb 1i9 2p1 1in,2ob 18a 2oo 18q,2oq 19f 2oi 1a6,2mp 1ab 2mm 1bh,2s3 1o5 2s4 1os,2te 1qu 2t0 1su,2nv 1pu 2nf 1po,2m9 1mc 2m1 1mr,2na 1li 2o9 1mj,2oh 1ml 2oa 1nn,2ob 1s3 2nj 1t5,2uf 1pj 2v3 1ra 306 1sk 317 1td 333 1uo 35j 20m,35i 20m 374 211 372 216,37n 21c 38c 20j 38l 214 38b 21g,38c 20i 38u 1vs 384 201,38t 1vr 38s 208 394 208,3a7 203 39v 216 39b 21m,39v 217 39v 21r,3a2 20j 39s 205,3a4 20k 3ad 209,3b3 209 3bb 21g 3av 21j 3b0 221,3bb 21f 3bn 228,3b5 20p 3al 20g,3b7 20p 3ak 20t 3af 20o,2v3 1r8 2v4 1u9,305 1sl 303 1us,31h 1tl 31a 1vo,338 1us 332 206,34v 208 34v 20m,3fo 1v1 3fn 1vb,3fn 1vb 3fp 1vo 3g1 207 3lt 259 3m9 25g 3mn 25l 3o6 24c,3k7 23p 3k7 23k 3ka 23g,3kq 24a 3l1 24a 3l6 247 3l8 241,3k7 23s 3k9 23v 3k7 246 3k1 24d,3kl 248 3ke 248 3js 24q,3k0 24c 3jd 24s,3ju 24p 3jj 250 3jg 258 3jg 25l 3jj 263 3jj 26i 3je 268 3ja 256 3j5 25a 3iv 25d 3i9 25j,3i8 25i 3iq 259 3j7 250,3je 24s 3j5 251,3kj 23k 3ke 23t,3ku 23q 3l4 23l,3h4 205 3i8 216 3il 21m,3i4 204 3id 20g,3jq 21r 3l2 230,3j7 22f 3jf 22o,3mf 25k 3mp 24t,3mp 24t 3ns 244,3n0 250 3ns 24c,3mq 258 3n3 257,3mk 25i 3mo 25a,3mm 25l 3na 25d,3na 25d 3nq 253,3nq 253 3o5 24d,3fo 1vh 3g9 1v2 3gn 1uk 3gt 1u4,3g1 1ur 3g1 1uf,3ga 1ud 3gf 1u2,3g1 1v0 3g2 1up,3j5 20m 3jp 214,3lp 236 3mf 245,3lb 22e 3lo 22o,3he 1vc 3hk 1vl,3hh 1up 3ho 1v6,3gg 1vh 3gk 1vv,3fs 204 3fb 20p 3jh 24h,3jr 24q 3kt 25q 3ln 254,3f3 21s 3iq 251,3jh 25r 3k4 267 3kt 25m,3k6 264 3sk 284,3kv 25p 3rq 27d,3mh 25k 3r2 26n,3nm 256 3ps 25p,3nc 26n 3o3 26u,3ob 269 3oj 268,3ol 25r 3p5 25t,3qa 27c 3r3 27e,3l6 262 3ll 264,3k1 25f 3k7 25m,3gj 22i 3h9 238,3fs 21n 3fr 221,3gq 21a 3hq 22e,3iu 238 3jt 246,3l3 24t 3l0 255,4fl 2hq 4pd 21n 50r 2cb 54j 289 5av 2ic,4mv 25u 4mv 28r 4p7 27t 4rg 29h 4rq 276 4st 284 4sv 271,529 2an 52h 2d2 53c 2ce 54n 2d9 55n 2bl 56g 2ce 56j 2bq,4j9 2jh 4qd 2ek 51v 2k8,4n9 2gq 4nb 2hl 4p2 2h6 4pm 2hq,4pm 2ho 4r3 2h6 4sg 2hq 4t2 2gl#B 399 21d h,B 3ea 22b 99,O 3b8 206,O 3aa 201,O 396 1vp
