Front Detailer running chain
Talon05
Cannon Fodder
I’ve found the crank arm is coming into contact with the derailer when the large front gear is selected so I’ve reduced the tension on the barrel adjuster and that seems to have cured it
Now I’m finding when I’m in the middle front gear, the chain rubs the front Detailer when using the 3 smallest rear cogs
Your front shifter has the ability to micro index so you can shift it over enough to stop rubbing. Give it a try and report back.
I would say just take it into a bike shop, but that 16yr old pimple faced punk who has title of Chief Bike Mechanic, but only on Sundays because no-one else wants to work, has probably never even seen a Triple Chainring setup.
