Yeh i have a hanger that has thread in it for an axle. Where did you get your axle made?the 150mm maxle... is a 150mm version of maxle you find on RS forks. it comes on GT DHis i believe... im not sure on avaliablilty from monza(sram), i side with make my own over give monza any of my hard earned...
im guessing you got the 3 different hangers when you got the bike? one is standard, one is maxle and one is saint i think.
i havnt yet, but i'll make it myself. some 12mm al tube, a m8 tap on one side to screw in and locktite a bolt, and a m10 die to puton the existing nut, i'll be set.Yeh i have a hanger that has thread in it for an axle. Where did you get your axle made?
Haha wow, your game.......Axle-age fail-age= Disasterous-agei havnt yet, but i'll make it myself. some 12mm al tube, a m8 tap on one side to screw in and locktite a bolt, and a m10 die to puton the existing nut, i'll be set.
when i get around to it.
wont gaurentee its strength. we will see.
hrmm... yeah, im thinking it will deform pretty badly before it snaps. brake rub will be a bit of a sign. i might run m10 bolts from the ends instead of a nut on one side... long enough that they cover the section of max shear stress, between the hub and frame, so that area will be solid, the rest hollow.Haha wow, your game.......Axle-age fail-age= Disasterous-age
