I have the D4.Get a nitecore i4 intelligent charger. Charges everything from AAAs to li-ion 18650s that are used for bike LED lights. Very cheap too. I have one for work for charging all our CREE flashlights and one at home for charging everything.
That is pretty. They will but I think you have to do AAs and AAAs in pairs (Well I always do) where as the bigger Li-ion batteries can be charged singularly.I have the D4.
Very happy - mine's used for 14500's, CR123's and 18650's. Never tried it on AA or AAA's but it does them.
http://charger.nitecore.com/product/digicharger-d4
I've got a Maha too, but this one - https://www.videoguys.com.au/Shop/p...zardone-battery-charger-analyzer-mh-9000.htmlI used to run a Maha charger back when I was a photographer and it never once let me down. Had 8 sockets for aa/aaa and would charge each individually. Cost me about $180 at the time and was money very well spent.
I've been using one of these for a few years now, does very well..https://www.videoguys.com.au/Shop/p...HaZo5cl2PH_02OGS7gKd0qnCL5qdKSXDJIaApN68P8HAQ
That's the one I have, or a later model of it... Might still have it actually, will look!
It's a bit more complex than your standard 'wall socket Energizer charger' but I wouldn't' say the device is difficult to use. Actually, if you want to just chuck your batteries in and let it go, it defaults to charging at 1A if nothing is pressed within a few seconds of powering up. (Unlike a cheapie wall socket charger however, it will charge the batteries independently rather than cutting out as soon as one of the batteries reaches max. capacity).Is the Maha easy to use? I don't have a degree in electrical engineering.
That's actually who I bought mine from. Top service, would definitely use again.+1 for the Maha C9000.
Since you're in Melb's outer east, go see these guys in Mitcham.
http://www.protog.com.au/buy/maha-powerex-mh-c9000-wizardone-aa-aaa-battery-cha/9000
Very easy. There are more complicated cycles available, and as AngoXC mentioned some of the cycles are very time consuming, but most of the time you can just pop the batteries in, leave it, and when you come back there will be little 'Done' labels under each individual battery - yep, this unit tracks each battery's charging individually, and tells you when each one is finished. Best battery charging investment I've ever made!Righto, the Maha is the front runner. The performance of my Nitecore torch has been spasmodic so that goes against the Nitecore.
