I have a problem, that I think I have a good idea what the solution is, but I thought I might throw it to the forum to see if you can shed some more light on it.
I ride trials, and as a result of my bike setup I get seriously sore hands after and hour or so. More specifically on the underside of my ring finger on my right hand, it feels as though the tendon is trying to tear itself in twain. So I've had a bit of a fiddle with the sweep angle on my bars, which helped a little, but more with my wrists than my fingers.
So after that I also tried swapping my grips, from the DMR zip grips back to an old set of Oury's I had lying around. I went for a ride for a while, but it wasn't until I was starting to do some bigger moves that I realised that the grips were slipping and thus my finger slipped off the brake and I landed on my arse. So I had to take it a little easier for the rest of it. My hands felt pretty good after the ride, but I'm not sure if it was because I was taking it easy or because of the new grips.
The thing is I really like to be running thinner grips because it reduces arm pump (When you have your hand locked on the brake for long periods it takes less effort when you have a smaller radius to grip) But if it's gonna fuck up my fingers then I'll avoid them. I guess I should also mention that I have pretty big hands, and take the largest gloves I can get eith XL or size 12 depending on brand.
So I guess there are a couple of questions that come out of all of that:
1) How can I stop my grips from slipping on the bars so I can get a good test before I think about buying some Oury Lock-ons?? I don't want to touch Wire as I always cut my hands, and in the past I've used the Hairspray trick, but even then it wasn't the best solution.
2) Does anyone else have similar problems and found a way to stop the pain??
3) What other grips would you recommend that are FAT and come with lock-ons? I really like the Ourys but at $65 it's a little more than I actually want to pay.
