Grip said:AND I'M A BLOODY DICK HEAD!!!!!! The word is "ROTOR" and yet for some reason (and I'm going to blame exhaustion here) I was seeing j5ive trying to bend his CALIPER into position with his thumbs.
Jesus-tap-dancing-Christ! But at least you've got to admit there REALLY would be something wrong if he could bend his caliper with his thumbs.
to get the best alignment, do this, but with the brake on, fit shims into the gap between the caliper and the mount. then when you let the brake off the pads will move out evenly.juzza said:What you should do is loosen the caliper from its mount( not so its off, but is loose). Then once the pads are still between the rotor, grab the lever on pretty firmly and re-tighten the bolts to the caliper mount whilst holding the lever. It may still rub but shouldnt as this is the only way to perfectly allign disc brakes. The pads automatically position themselves every time you brake, so after there is no rub . If it still rubs then you may have a slightly warped rotor.
lupine128 said:to get the best alignment, do this, but with the brake on, fit shims into the gap between the caliper and the mount. then when you let the brake off the pads will move out evenly.juzza said:What you should do is loosen the caliper from its mount( not so its off, but is loose). Then once the pads are still between the rotor, grab the lever on pretty firmly and re-tighten the bolts to the caliper mount whilst holding the lever. It may still rub but shouldnt as this is the only way to perfectly allign disc brakes. The pads automatically position themselves every time you brake, so after there is no rub . If it still rubs then you may have a slightly warped rotor.
