Help with disc rotor problem
Hi All,
I have an older cannondale lefty with a 4 bolt front hub. The discs are magura Julies. 180 on the front and 160 on the back. I need new rotors which are very hard to come by in Australia. The only 4 bolt 180 mm I could get was a Hope mini from CRC in. The depth of the rotor circumference (where the pad does its work) is significantly less than that of the original julie rotor. The hope maxes out at 14mm and the julie rotor is a constant 17mm deep.
Will the hope rotor work ok? Can someone suggest an alternative disc or should i toss the 4 bolt hub and look for a 6 bolt replacement. If I do that will a standard shimano rotor for example work with the Julie calipers?
Any and all comments welcome
Cheers
Jock
