hellmansam
So I was looking at a couple of Shimano cranksets I have in my parts box and I remembered reading something about you can use non Boost cranks on Boost frames in some instances. The cranks and BB fit ok in the Primal frame but chainline is a bit off. The tabs for the middle and outer chainrings are where the chainring should be. Could I make a spider out of a scrap bit of aloominum ? Prolly shouldn’t bother but ended up marking out BCD, inner and outer diameters. No machining gear, just a drill press and jigsaw. I’m planning to mount it via recessed holes (it’s 12mm thick) using the 64mm BCD for the granny ring so it will end up face to face with the 104 BCD tabs.
Just because I like doing stuff like this.
g
