vodka recipe from HOWEZELL,
(this was sent by PM as HOWEZELL decided not to post it due to it being illegal> in fact it is only illegal to distill vodka not to construct a distillery so these are his plans, a simplified version of a fractional still, should still work (im gonna try it) and be a dam lot cheaper than a proper one. Also this is for eduactional purposes only any harm or death that happens to u is not my problem or responsibility!)
well we just went down to the store and bought 2m of copper piping 2 tins, one with a metal removable lid and one with an open top. then get a soldering iron or something hot enough to melt solder and then get some LEAD FREE solder. put a hole in the removable lid of the tin and then put the pipe through the hole and solder it in. once it is soldered in then follow the pipe up about 10 centimetres and bend it at a right angle then follow the pipe another foot or so from the first bend and make another one so that the pipe is now facing downwards.
Now the tricky bit, bend the remainder of the pipe into a spiral and leave about 15 centimetres of straight pipe at the end the spiral. IT MUST FIT INTO THE OTHER TIN because this will be the tin that cools down the alcohol vapors.
Now at the bottom of the tin that doesnt have a lid drill a hole that the pipe can fit through, u can use plasticine or solder or whatever to cover it up once the pipe is through.
Now for the "broth," Just get a big ass container, im talking like 40 litres or something, now put in about 30 litres or however much u want and put in about roughly 1 part of sugar in per 10 litres. ie if u have 30L put in 3kg of sugar. then just add some yeast, honestly it doesn't matter how much, from 1 pinch to a litre it makes no difference.
then just put a lid on it and leave it in a nice warm place inside and wait. it might be 1 week, or 2 or three, but when it stops bubbling fill up the tin about halfway with broth and heat it up to about 80 degrees roughly, (it doesn't really matter just keep it on the boil.) and make sure there is water in the coolant tank. have a bucket out the end of the pipe and collect the shit.toss out the first bit of stuff u get because sposedly its metho not alc and then just get the rest of it. u can run it through some charcoal if it makes u feel better but i have my doubts that it does anything.
if i missed anything just give me a yell (regards, jack) u can post this if u want
(also you should discard the first and last 5% of the brew if u want and exact number if you don't do this it is not metho, but phenols (even worse) that you will get in your brew and these althought not deadly give u a very baaaad hangover, so wast 10% of ur booze and save ur head!)
enjoy
