Richard Devey
hello, anyone make a home made 34 fox seal driver tool, not keen to pay the $50 ish bux for it, and actually what do you use to tap the damper ends out????
I just use a length of PVC pipehello, anyone make a home made 34 fox seal driver tool, not keen to pay the $50 ish bux for it, and actually what do you use to tap the damper ends out????
This.I just use a length of PVC pipe
Any decent plumbing supplies shop should have a variety of internal diameters to suit your fork
Just make sure you cut the end square and sand off the sharp edges
Or if you don't have calipers, just take the seal in with you and find the pipe that works! On a 32" fork I've even pulled out the end plug from a paint roller cover and used it - worked perfectly.This.
Just measure diameter using caliper then buy closest match from hardware store . I ended up using a pvc pipe connector it had a nice smooth bevel and other end with a wide area to grab onto
I use a piece of timber dowel. Drilled a short hole in the middle of it to fit the little bit that pokes out, pop it on and tap away. Sure as hell never going to damage anything using timber to tap it out.and actually what do you use to tap the damper ends out????
the little bit that pokes out....fit the little bit that pokes out, pop it on and tap away.
True thisthe little bit that pokes out....
Its very common to use a deep 10mm socket and a old/spare foot nut if you dont have the tool, you can use your existing foot nut but it will mark it a little bit, alot of lazy bike shops use this method and you can pick it by little marks on your foot nuts.
