Swinger 6-way: Yeah i'm running around 30% sag when i have no preload on to measure spring viability. Or as best i can measure by myself, so i think the spring weight is right. I do crank the preload on b/c i found myself catching my bashie and pedals and thought i might be sitting too low in my travel. (see that tiny rock in the far right of the picture i attached, closest to the photographer? the one at the bottom of the rock fall? the shadow of the tape points the offending spot out. not very big is it? i continually destroyed my bashie etc when i was slightly wide on the line... ) (and yes, reindeer ears - don't ask)
I'm running the 6-way b/w 100-120psi. Screwed in the bottom out control on the swinger in a few turns, and run a few turn of low/high speed comp for the hell of it. It seems overdamped the 6-way. I really don't know how to set it up. I've barely got any rebound on at all, maybe one turn, and it seems really slow still, so i think there may be a problem there. It did gather dust all winter... I want it to spring back with more life so i can jump things easier...
fox40's. some preload, not much rebound on of late. Once again, so i can hop it up over things, jump etc. a little easier.
Any thoughts? Cheers.
correction: LBS reacons i'm running 50% sag! anyone running a demo9pro? i got a 400*3.0. i'm 80kg. what are weights are others running?
