ibis bikes
get one!!
i got a HD recently, very agile bike.
in technical terrain and/or if you like just generally like hooning it up, they are definately worth looking into
What forks are you guys running
Are you guys running 160 or 180 mm forks how does the ibis climb with so much travel
Cheers
160mm, or 150mm when it's in HD140 mode
no travel adjust on the 160's, Fox Float Fit, climbs great
can dump the travel to 130 on the 150's, but i don't bother
more about technique
obviously it doesn't climb as well as a 10kg XC bike!
the DW suspension is amazing, sprints well, climbs well, is more active under braking and pumps speed in rough sections.
my rec would be,
HD in 160 mode, Fox 36 or RS Lyrik, x9 build with mid cage, single ring with Ibis/MRP guide, 50-70mm stem, +710mm bars
