With my massive strava estimate of power being 109W...The AOC rang, they've got an opening in the Tokyo 2021 track cycling team!
Err, maybe the marathon team then...With my massive strava estimate of power being 109W...
Bummer. Slx?View attachment 370533
So this happened on the second ride... Splines on crank arm stripped out...
Who put it together?View attachment 370533
Sure the splines are stripped?View attachment 370533
Can't help think it was loose long before failure...sucks but.So this happened on the second ride... Splines on crank arm stripped out...
Deore.Bummer. Slx?
The LBS.Who put it together?
On the crank arm itself certainly seemed rounded out on the inside. Yeah almost looked like it didn't have enough spline.. and that perhaps the bolts weren't tight..Sure the splines are stripped?
More likely the crankarm hasn't been installed with enough spline available.
Post a picture.... for the peanut galleryDeore.
The LBS.
Didn't take a decent one, just threw it at the LBS's door to fix.Post a picture.... for the peanut gallery
I love the dust cap core removersDERT tubeless valves, just a lil' bling to match grip clamps and add some colour.
Interested - where'd you buy it?Upgrades added to first post;
- Shimano MT500 ispec dropper is on for trial as stock KS dropper lever was shite. Incredible upgrade for $35.
Out of stock atm.. https://www.bikebug.com/shimano-deore-m6100-seat-post-dropper-lever---i-spec-ev.htmlInterested - where'd you buy it?
Shimano 12 speed boost cranks use spacers between the BB and the arm. The parts diagram calls for one on each side, but when i went to fit the Deore 6100 crank to the orange (same threaded BB as you) it only needed one on the drive side - if i used the second spacer on the non drive side it only engaged half of the spline but still allowed the end cap to be fitted.View attachment 370533
Yeah that was the problem, LBS added a spacer that wasn't meant to be there... only one spacer between frame and BB required for the 6100/7100 etc. 52mm chainline models.Shimano 12 speed boost cranks use spacers between the BB and the arm. The parts diagram calls for one on each side, but when i went to fit the Deore 6100 crank to the orange (same threaded BB as you) it only needed one on the drive side - if i used the second spacer on the non drive side it only engaged half of the spline but still allowed the end cap to be fitted.
Take the end cap off and see if you can see any spline exposed on the crank arm.
