toodles
Thanks for your input. No one cares.Frantic_on_manik said:if i want to save 80 grams of weight ill take a dump before i ride Lol
No one's cranky, they just don't care.Frantic_on_manik said:O come on it was just a joke didn't mean to make anyone cranky
toodles said:Thanks for your input. No one cares.
Do you just try to sound smart or something? Most of us realise this, it has been discussed before, and I don't think anyone apart from raceface (in their infinite wisdom) do this. Truvativ have done it in the past also, but neither company is known for their long lasting BB bearings.arpit said:I wanted to know what type of bearings the hub used. A common mistake is for bicycle parts companies to use full complement bearings in 'spinning' situations like bottom brackets. This makes for a very strong device, but as soon as a grain of dirt works itself in, it acts as an abrasive, and can't be pushed out. The demise of the device becomes imminent.
Yeah that's great. Until you actually care about your bike's weight. It was funny the first time I heard the old "i could shit before a ride and lose that much weight" argument. But now I think people who say that are daft. In the end they're picking up another bike in the carpark and going "damn that thing is light - how'd you get it so light?" SUM TOTAL people. 20 grams here and there and your bike weighs 2-3 kilos less than the other guys. Yes I know 20 grams in a hub is nothing but 20 grams per component is a lot.arpit said:I care. It's certainly a cheaper way of saving weight than buying an expensive headset. It could be easier than replacing your headset too, depending on what you ate last night.
but if your bike is also 80 grams lighter and you log 80 grams, you are collectively 160 grams lighter.arpit said:I care. It's certainly a cheaper way of saving weight than buying an expensive headset. It could be easier than replacing your headset too, depending on what you ate last night.
I sure as hell don't try and sound dumb.udi said:Do you just try to sound smart or something?
SO you acknowledge that major manufacturers have done this?udi said:Most of us realise this, it has been discussed before, and I don't think anyone apart from raceface (in their infinite wisdom) do this. Truvativ have done it in the past also, but neither company is known for their long lasting BB bearings.
That's nice, but I was interested in reality, not Udi's assumptions.udi said:All cartridge hubs i've pulled apart (from cheap to the peak of the pyramid) have had cartridge bearings with retainers, so I would assume the illicit is no exception.
I'm not assuming anything, unlike yourself. I merely want to know what of bearings they use.udi said:but to assume they don't have a clue is going a bit far.
1. For a law student I thought you'd be better at interpreting what he meant.arpit said:I sure as hell don't try and sound dumb.
When will the zero stack headset be avaliable, and how much will it cost??The onepointfive headset that i've been using for ages rocks.. (on the Splinter). The top stack height is 6mm on the proto which rocks... they understand when the simple things work well and do a really noice job going about it.
Yep... it was but we would have stuck up for you anyway, Udi.Maybe banning the sucker was a bit harsh... i'll guess that was for something else.
You mean needle roller bearings? Axial loading is the problem there. You need to take care of the side loads that can occur with wheel bearings & frame pivots.why dont people use roller bearings in hubs and frame pivots dont they have better weight distrubution and longer lives than ball bearings? someone let me know
You've just won some free characters: .,'":;/? and so forth. Feel free to use them whenever you like!no i mean straight roller bearings they way i was looking at a diagram the other day it seemed like they would be perfect for alll mtb applications every one all ways seems to be bitching about how all the stress is loaded on to one or to BB leading to short lives it seems to me that the roller bearings seem to have a much snugger fit into the bearing assembly thus making for much better load bearing capabilities i see your point however in regards to wheelsets but for frame pivots i think they would be ideal
