Nautonier
I got my Vorsprung Luftkappe and tried installing it today. Everything went smoothly and as per Steve's excellent instructions until I went to pump the fork up and equalise etc. The forks are stuck down, somehow air is getting trapped in the lowers and sucking them down. Even at 100psi they won't extend to the full 170mm. There is no 'top out' as Steve describes as they are nowhere near maximum travel. I tried the cable tie method to 'burp' air out of the lowers and it didn't work.
I also tried undoing the bottom bolts again and that released the air in the lowers. The problem was that the air shaft wasn't full extended, so the only way I could get it to extend again was to pump it up while the lower bolts were detached. It seems like the air shaft gets sucked back up the stanchion, so the only way to attach the lower bolt is to compress the lowers onto the uppers, which then creates the vacuum that sucks them down.
When I initially inserted the air shaft back into the stanchions, I made sure the shaft was fully extended and didn't attempt to push it in. It may have gone in a bit when I pushed the lowers on to make the bolts line up with the shafts.
The forks have just had a full service and were working perfectly before I took them apart. Since pumping up the air chamber while the forks had the lower bolts off I'm getting closer to 170mm travel and the Luftkappe seems to be working well, but I can still pull the stanchions much further out of the lowers.
Has anyone had this issue of the air shaft sucking back and the subsequent vacuum in the lowers reducing travel before? Am I good to ride or do I need to take them apart again? Or am I missing something really obvious and looking at a one way trip to the f@*kwits thread? I know the way the Luftkappe works is to create negative air pressure, but that should only be after it equalises. Initially, as per Steve's video, it should be topping out hard at the absolute end of its travel, which, I would guess is even more than 170mm as the top-out bumper has been removed (I can pull the stanchions out to about 180mm).
