What drugs are you smoking? The Stinky is a freeride (oh I hate that word) bike with a relatively high bb height, short top tube, and steep head angle. The IH is the complete opposite designed to run sag, and go downhill!six9man said:they are a fairly similar ride only subtle differences
Click here for the AMB reviewRalph said:It was also in AMB mag and they gave it a really good run-down.
good luck !
When you say air assist removed do you just mean release any pressure in the fork or taking out the top cap with the valve? Because swapping the top cap wouldn't really do anything...the F.H.B said:The forks are just pretty below average, need to have the air assist removed (your LBS should have already done this) cause it was blowing the seals!?
otherwise a great bike, but after less than a month on mine, it's time to upgrade the forks.
Dude, quit while you're behind.sims_65 said:i would have to be against u there (in a good way) because i believe that the 05 stinky has been pushed more towards downhill than freeride it has a smaller frame for better control on the downhill tracks!
Umm, how? Why would Kona make their "freeride" bike a downhill bike, when they already sell "downhill" bikes (the Stab range).sims_65 said:i believe that the 05 stinky has been pushed more towards downhill than freeride
Dude, sit down before you hurt yourself.sims_65 said:i would have to be against u there (in a good way) because i believe that the 05 stinky has been pushed more towards downhill than freeride it has a smaller frame for better control on the downhill tracks!
The "fix" is a new top cap (without the air valve) and a firmer spring, to compensate for the lack of air assist. The kits that came from Norco also had a different top crown, although I'm 100% sure if that is related to the seal issue.kalem said:When you say air assist removed do you just mean release any pressure in the fork or taking out the top cap with the valve? Because swapping the top cap wouldn't really do anything...
HAHA what planet are you onwombat said:Would have been nicer though if the original design just worked in the first place....
