Gluey_trails
As the title asks, does anyone know? I have very little idea how to work this stuff out.
Basically I have a temperature sensor and it is to read a value and change the colour of the LED. At the moment it just turns on and off every 6 seconds or so.
This is my code.
Can anyone help me?
This is my code.
Code:
// Output
int redPin = 9; // Red LED, connected to digital pin 9
int greenPin = 10; // Green LED, connected to digital pin 10
int bluePin = 11; // Blue LED, connected to digital pin 11
int sensorPin = 0; // select the input pin for the potentiometer
int sensorValue = 0; // variable to store the value coming from the sensor
// Program variables
int redVal = 255; // Variables to store the values to send to the pins
int greenVal = 1; // Initial values are Red full, Green and Blue off
int blueVal = 1;
int i = 0; // Loop counter
int wait = 200; // 50ms (.05 second) delay; shorten for faster fades
int DEBUG = 0; // DEBUG counter; if set to 1, will write values back via serial
void setup()
pinMode(redPin, OUTPUT); // sets the pins as output
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
if (DEBUG) { // If we want to see the pin values for debugging...
Serial.begin(9600); // ...set up the serial ouput on 0004 style
// Main program
void loop()
// read the value from the sensor:
i += 1; // Increment counter
if (i < 0) // Second phase of fades
redVal = 1; // Red low
greenVal -= 1; // Green down
blueVal += 1; // Blue up
else if (i < 575) // First phase of fades
redVal -= 1; // Red down
greenVal += 1; // Green up
blueVal = 1; // Blue low
else if (i < 790) // Third phase of fades
redVal += 1; // Red up
greenVal = 1; // Green low
blueVal -= 1; // Blue down
else // Re-set the counter, and start the fades again
i = 1;
analogWrite(redPin, redVal); // Write current values to LED pins
analogWrite(greenPin, greenVal);
analogWrite(bluePin, blueVal);
if (DEBUG) { // If we want to read the output
DEBUG += 1; // Increment the DEBUG counter
if (DEBUG > 10) // Print every 10 loops
DEBUG = 1; // Reset the counter
Serial.print(i); // Serial commands in 0004 style
Serial.print("\t"); // Print a tab
Serial.print("R:"); // Indicate that output is red value
Serial.print(redVal); // Print red value
Serial.print("G:"); // Repeat for green and blue...
Serial.print(greenVal);
Serial.print("\t");
Serial.print("B:");
Serial.println(blueVal); // println, to end with a carriage return
delay(wait); // Pause for 'wait' milliseconds before resuming the loop
