stirk
Bunnings is a shameful rip off shop, don't buy their alcohol.
http://www.altronics.com.au/p/t3038-isopropyl-alcohol-2-litres/
With FreightBunnings is a shameful rip off shop, don't buy their alcohol.
You're just afraid of the flames a 2 litre bottle would create!
Hopes would solve all the shimano issues. So would Avid, magura, and even Hayes...Silly Poodle you know your my second account....... Stirk is my third..... or is Stirk your second i forget it gets confusing...
Back on topic.... We cant have a brake fight with out at least one...
HOPES!!!!
Causing squeal but not spongy feel....sounds legit. :dizzy:Hopes would solve all the shimano issues. So would Avid, magura, and even Hayes...
The problem is in your lever body. There shall be a bunged seal or similar.
I treat my customers' brakes the same as my own, even Avid (except with a healthy dose of contempt for no extra cost).Duckman I see your point of view from a shop where time = money, however cleaning rotors of the shit that is on them when changing pads whether resin-sintered, but esp sintered to resin, is good practice. i.e. in order to get the pad material into the rotor, from the actual pad that will be doing the braking. No need to take a shortcut for peeps not on the clock have the time to pull a few more stops.
Metal pads will help, as they are more tolerant of dragging.Duckdude, what is the best way to avoid/reduce chance of glazed pads? A female friend loves to constantly drag her brakes, the resultant noise is fucking annoying. It's like an orgasming seal! Should I recommend sintered pads? My current advice of "get off the brakes" seems to be not sinking in and I'm a terrible coach.
Indeed! Every puddle I go through at the moment, the next touch of the brakes is horrible to my ears! Good to know it's normal.Metal pads.... quieter than resin until they get wet....
You get a couple of weak squeaks and then silence again. Gets your mates riding with avids excited if only for a short period, it's enough to make them feel normal for a moment and that's what matters.Indeed! Every puddle I go through at the moment, the next touch of the brakes is horrible to my ears! Good to know it's normal.
Yep. It's the lack of compressive power. He will need to pull the lever assembly apart, just to be sure.Causing squeal but not spongy feel....sounds legit. :dizzy:
Cheers duckstar. Lucky girls don't ride in the wet.Metal pads will help, as they are more tolerant of dragging.
Word of warning: they will feel utterly dreadful at first and do need more attention to bedding in than resin, but once that's done they'll perform a lot better and quieter than resin until they get wet....
Yep, calipers look good mate - both moving equally. Your resin pads will have metal flakes in them too; that's normal.yes i had metal pads and they are fantastic, and i know that wet squeal!
here is a vid of the rear pistons in action, seem ok to me
https://www.youtube.com/watch?v=I_gXdy_aEu4
the new pads are resins, but look like metal flakes in them...???
going for a ride wed night, since i live in the hills, ill ride down the hill and get them hot and see what happens
