Jonny Sprockets Outlet Store now live. FREE FREIGHT!
Front hub is exactly the same. Rear EVO has a 17mm diameter axle compared to 15mm on older model and slightly higher POE on the EVO too.
Conversion kits can be purchased but there's nothing wrong with the non EVO hubs.
Thanks for chipping in guys.
The chain goes something like this-
Hope Bulb-> Hope pro II-> Hope pro II evo-> Hope pro II evo 40t
So its a little older hub, but still super high quality and loud, firm engagements. We will hopefully be adding more soon, so keep an eye out.
Not sure if I am 100% correct, the non evo version had a slightly smaller axle, to convert to 142 you need to purchase new axle, not just end caps. I bought the kit a while back for 30ish aud. I also think the evos have slightly better bearings, not that I've ever had bearing issues with hope.
Can anyone confirm if the freehub body will be compatible with a Hope pro 2 Evo hub?
My plan is to swap an XD driver from my current wheelset with the new hub body on the pro 2.
Freehub body not compatible. Different (larger) external diameter on the EVO axle.
I have non EVO with a 12mm through axle. I'm able to change from 142 x12 to 135 x 12 to 135 x 9 QR with end caps alone. Need a new axle for 10mm bolt up and 10mm through.
