Guiver
Built more as a show off piece than something im going to ride.
Needs a few mods to the frame to make it bomb proof.
Updates from last time;
Pimp'n paint jop. (i say pimp'n... i sprayed it green then did a white splatter over the top (get your mind out of the gutter))
Front triangle is bomber has not moved at all.
I bent the rear end when i took it for a Shuttle run last year but we bent it back and Jeremy zip welded some small c section gussets along the inside of the chain stays *fixed*.
Might beef up the rest of the rear just sometime just in case.
Weight: 13.5kgs
the shock has had a hard life and on its 3rd owner without a rebuild so it feels a little sad.
(mk1 build here: http://www.rotorburn.com/forums/showthread.php?t=127378&highlight=jtr)
