tasty.dirt74
Frame - 2017 Specialized Stumpjumper S Works
Rear shock - Ohlins
Front shock/fork - DVO Beryl. Set at 140mm, can be run at 160mm if neede
Handlebars - Ritchey 720mm. Flat
Stem -
Headset - Stock
Grips - ESI
Saddle - Specialized BG
Seatpost - brand x showing in pic is 125 external. Will be replaced with 150mm internal asap package arrives..
Front brake - XT . 180mm rotor
Rear brake - XT . 160mm rotor
Cranks - XT. 170mm
Chainguide - Stock
Chain - XTR
Pedals - XT
Rear derailleur - XT
Rear shifter - XT
Cassette - XT
Front hub - Hope
Rear hub - ? Centrelock
Front rim - Easton alu 30mm internal
Rear rim - Easton alu 30mm internal
Tyres - Minion DHF and DHR. Butcher on rear atm.
Being a poor broke hospitality worker means that new bikes are generally out of the question, but am always searching for good deals..
My current ride is a Specialized Stumpjumper 2011 29er with some nice suspension attached. Unfortunately there is some brake hose rub on the chainstay which I didn’t like the look of.
I started looking at options.
Complete Polygon, or frame only and swap parts..
Somehow managed to get a N.O.S 2017 frame through the LBS for $2800. It had to be built by the shop for warranty, so was a extra $300 for labour and some extra bits and brake bleed. So at the end of the day still came out under the price of a Polygon. Pretty happy with the end result, as it rides better in every regard to the good old Stumpy.
And what I think is the nicest part of the whole bike is the metal head tube badge..
Rear shock - Ohlins
Stem -
Headset - Stock
Grips - ESI
Cranks - XT. 170mm
Chainguide - Stock
Chain - XTR
Pedals - XT
Rear shifter - XT
Cassette - XT
Front hub - Hope
