Z
Zaf
Guest
With Mint355's help, finished the build for this last night.
2015 Kona Honzo (Large)
Pikes, e*thirteen TRS+, Flow EX/Hope wheels, XT drivetrain and a whole lot of fun.
Is the frame itself really stiff or a bit forgiving?So far is pretty fun!
The pikes came with two tokens in it standard, which I've since pulled out. It was ramping up way too much, now feels very plush and pushing through nicely without bottoming.
Taking a lot of getting used to being back on a hardtail, legs killing me after the ride.
The ride feels great, so much traction, well spaced cockpit, turns in beautifully.
Not sure if it was my legs getting used to the hardtail again, but by the end of the ride I was feeling tired pedaling it around. But the heavy pedaling want apparent until much later in the ride.
sweet, might have to put that on my list of upgrades. Rad bike indeedI went with 140mm and a 51mm which keeps an almost identical trail measurement.
I've not run it with 120mm,but the bike feels brilliant now. Starting to get a hang of it, got a top 10 on a descent tonight on strava with it. Steering feels really intuitive and direct.
Just needed to get the hang of getting out of the saddle a bit more, the Yeti has taught me some bad habits with lazy seated pedalling.
I'm running a Pike RCT3 140mm with 51mm offset on it, and it's been perfect for it.Hey mate, just putting together some parts for a Honzo ST myself. What fork are you running?
I'm going down the Boost route, but can't decide between the much cheaper option of a Yard RC or a Fox 34 Fit4.
I want to run boost to future proof it and potentially run 650b+ , so also can't decide which rims to buy.
Kinda discounted DVO as they don't do a boost at the moment. I have a front hub, and it 110mm. I'm also going with Pro 4, and depending on wheel size choice, it's either DTSWISS XM551 or Stan's Flow Mk3.I'm running a Pike RCT3 140mm with 51mm offset on it, and it's been perfect for it.
I'd be inclined to look at the DVO Diamond for the bike as well, they were on special recently, but not sure what budget you're clocking in at. Mint355 has been running the Diamond's on his Canfield EPO and they're a nice bit of kit, and due for a release in Boost soon with like an espresso finish on them (which would look damned matchy sexy on the 2016 ST frame's finish).
I hear what people have been inclined to do is get a Yari and then get the internal serviced in for an Avalanche or Push damper assembly, a quick way of getting that performance boost out of it whilst cashing in on the stiff chassis. But the Pike has been flawless, perfectly matched for the bike, and seriously recommend having it out at 140mm, bike feels great with it.
I dunno about the 650b+, I will say it's important to run the bike with a decent volume rear tyre to keep things comfortable out the back (this frame with all it's gussets was a great deal stiffer in its ride than the Explosif I got to ride prior to it).
I've been running Hope Hubs laced to MK1 Stan's Flow EXs and they've been bombproof. The one spoke I've snapped was from a damaged point when a stick intervened and shifted my chain onto the spokes (that took 6months to break in proper). I'll be looking at getting some Hope Pro 4's with Easton ARC 30's as a replacement, but toying with going upmarket and getting the guys from Wheelworks NZ to make me up a pair and seeing if they can customise the decals to match the forks and frame colours.
I'll keep my eyes peeled for more boost options, but erring towards the Fox. I have a Pike on my SB6... and love it, but fancy something different.
Itching to get it built up...heard they're a ripper bike to ride. Also good to hear they feel lighter than the weigh, they're a heavy frame to start with!
Agreed, thanks Zaf, I've been thinking about another hardtail and your info is useful.Nice write up Zaf.
