Ok if this has been done then feel free to delete this thread.
What I would like to do is to create a thread where people can go to reference a tool kit/box where they can see what others have in there selection of tools. There are many tasks to working on a modern bicycle that require unique tools. Some can be purchased for a small amount, others are quite expensive and some are just plain home made solutions to problems created by engineers.
I will try my best to keep this OP updated with suggestions of others. Depended on how others take to this thread (I only check here once a day or so, please bear with me)
This can easily just turn into a list of every tool ever created. I want to hear about what people actually have in there tool kits.
So first of all let's start with the basics. What every person really should have:
Combination spanners 6mm to 17mm.
Hex key set 2.5mm to 10mm. 12mm.
Floor pump
Tyre levers
Torx key set
6mm to 19mm socket set and socket wrench
Combination plyers
From here things get a bit more specific:
Wheel trueing stand
Combination spoke wrench
Cable cutters
Crank removal tool
BOttom bracket removal tool for GXP/shimano threaded style BB
Chain whip
Cassette removal tool
Pedal spanner15mm
Chain cutter
15mm 16mm 17mm CupnCone spanners
Derailier hanger alignment tool
I will throw the floor open and hopefully we can get som real gems in here. If you include pics I will try and reference the post number they are in.
JP
Floor pump
Tyre levers
Torx key set
Combination plyers
Wheel trueing stand
Cable cutters
Crank removal tool
Chain whip
Pedal spanner15mm
Chain cutter
JP
